need a chain tensioner
matthurd
817
manchester NH
i'm not paying $75 for a chain tensioner no matter who made it.
i just need one that's basically 1 of the kit tensioners, i could order one from 1 of the sites but that would take 4+ days to arrive, was looking for something more local that could be here in a day or 2.
matthurd
817
manchester NH
I heard of some guy in Venice that has chain tensioning shims that eliminate the tensioner completely! http://motorbicycling.com/f23/tensionerless-chain-tensioners-22279.html
while i appreciate the link and like the idea, i'm not sure i have the clearance for it inframe, have you ever tried it on a worksman INB frame? i was having chain rub on my lower rear fork,so i need the tensioner to get the chain away from it. that and my chain may still work itself out a bit more since it hasn't been riden much yet.
Venice Motor Bikes
Mar 20, 2008
7,275
1,814
Los Angeles, CA.
One thing that helps is to add washers between the dropouts & the hub to space the frame apart for more chain clearance. I did it recently on a Worksman with no tensioner.
matthurd
817
manchester NH
well i'm gonna pick up a half link and try the washer trick i guess, see how it goes, if it works and starts to pick up a little slack i guess i'll pick up your shims, thanks for the info.
darkhawk22
733
8
Acworth, GA
I like the KIP one a lot but yes $75 is a bit steep. I would go about $45 on one. I like the shim idea too but I just want to put something on and be done with it.
Venice Motor Bikes
Mar 20, 2008
7,275
1,814
Los Angeles, CA.
I've found that the 1/2 links for the engine chain don't work very well. I use the smaller 1/2 link on the pedal chain instead. ;)
matthurd
817
manchester NH
guess ill try that venice, looks decent too vtec. working on the half link atm though.
this bikes becoming a nightmare tbh though :(
i didn't read this post a half hour ago so i messed up a half link, bought a new one n gotta figure everything out now.
