My original bike frame that I was going to use for this motor broke a few spokes because the sprocket came loose and bend, thus breaking some spokes. Also, because this was a re-badged Huffy bike for Shucks. It had a very hard to find rim size, and couldn't replace it. So I then found this at the same place I got my last one, both of which I bought for around 8 bucks each. Runs on BoyGoFast, and is a VERY tight fit, mainly for the carb. I may put a new air filter on later, Ill post a picture of it later, but its actually an oil filter for a Suzuki motorcycle. I also didn't like the throttle, was too cheap for me, and I in the midst of finding a new one, but temporarily, I have the throttle hooked up to and old 7 speed shifter. This works awesomely. Then the clutch is attached to the 3 speed front shifter. This also works awesomely, and means I don't have to use the brake handle. Anyways, here are the pictures, hopefully this one will last!
Oh, I also forgot to mention that I used a Helicoil's on two of the four head bolts, opposing corners. If someone has a stripped headbolt, not bother getting a new case, the threads will only last for so long. These, on the other hand, will last much better, because they are not a low quality metal. Plus, this was fairly easy to do, just get the right kit and drill.
