I have not stick welded. I have used TIG and MIG. I own a small MIG 130 with 4 voltage setting and a feed rate speed.
I've tried to do thinner sheet metal and punches through. I have not tried yet what I can try to do to stop this. This is just a short tack like weld. Let it cool a while. Then you do another short tack like weld some distance from the first one. Then after a while all the tack welds meet up and over lap a little and no punch through.
Sounds very much like more work than I should bother with though.
One other thing I did was where applicable I back up thin steel sheet metal that I am welding with a thick piece of copper plate to spread the heat out. Also the steel weld does not stick so well to the copper plate and so again no punch through.
Use that info for what it’s worth, but what I would like for myself is a torch with O2 and acetylene some day. I'd be using a fan tip and silver solder for the thin sheet metal.
MT
MT
