Morini Update! How's yours doin?
robin
618
77
Penticton British Columbia Canada
I forgot how good the full suspension setup really is ! took some pills and rode all day- engine is fully broken in and now it really pulls on the very steep hills--i like the 2 shoe which works great as a brake while slowing - there is some back pressure-no freewheeling but it makes it harder to pedal unless you take off the chain - bike works great on our abandoned KVR trail !
Easy Rider
Santa Cruz Scooter Works
Jan 15, 2008
2,145
7
Nor*Cal
I finally had time to swing by the shop today and found a sprocket laying around. Thinking it was a 47tooth sprocket, I thought it would be cool to reach FR31 speeds again. So I figured: its time to do some R&D (Ride and Destroy!)
After counting the teeth, I relized its only a 42 tooth rear sprocket. Darn! However my not so better side of me decided to change out my 64 tooth for the 42 tooth rear sprocket.
I'm not a big fan of going 45+ mph on knobby tires so I changed the rear tire to a Kenda K-Rad 24x2.3 and ordered the matching front today (a Kenda K-Rad 26x2.3)
Hopefully the front will be here before the weekend so I can test the top speed and see if it can fly up Calaveras Rd @ 50.
Pictures to come after the front tires installed.
w31john
87
san jose ca
My morini is kicking azz with a 56 sprocket. You and Dean need a shrink to help with your need for speed. good luck:)reddd
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
I am digging the gears on mine:D Helps me with my bipolar mood swings. Sometimes I actually come down a little then it starts all over again!:D
Hey GH, any pics of your bike? I'm dying to check it out. I take it the hub is holding up pretty good!
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
I have some bad news about my bike. My flywheel nut came loose and the woodruff key messed up the slot on my crank. I tried to hand align the slots 5xs but I couldn"t get it to rev up like it use too. It looks like I need to replace my crank. :-||
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
Update:
I decided that it would be better to just buy a new 9.4 hp Morini instead. I figured that my time tearing apart and rebuilding the motor plus part would almost equal the cost of a new motor. Plus it gives me time to port my old 5.8 cylinder.
I can wait to see what it can do with a 42 tooth sprocket. I'm pretty sure its going to be a stock 50+mph MB.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
GH, Take off the flywheel cover and make sure the nut didn't come loose. I thought the same thing so I started checking everything and found the loose flywheel.
I only cleaned up the ports a little. I plan on doing a full race port on the cylinder and piston. I have a few old tricks I want to experiment that I've learned from Trevor Simpson and Howard Combee cylinders. The key is to not over port it. I also plan on throwing a stroker crank and a single ring piston in there. Who knows, maybe if there's a bigger cc cylinder...that too.
The only problem I have is "TIME". First step is to:
Clean my r/c stuff off my work bench and dedicate a certain area for this project because it won't be an overnight port job. I should have it done for the next Death race. Look out FR31...I'll be gunnin for your crown next year! lol
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
If its not the flywheel nut, check the nut with the teeth that is on the kick starter side. You can only fit a cresent wrench on it. That too came loose once. Easy remedy is to plug hole under the carb, lay the bike on its side, remove clutch cover, clean the nut off with brake cleaner and use red loctite and let dry overnight before starting it. You can assemble it after you've tighten the nut. Just don't let the oil splash around in the clutch area. Also, try not to get any cleaner inside the clutch or you'll have to change the oil.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
The nut with the blue paint in the 2nd picture came loose on mine and started rubbing on the other bendix on the cover.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
No GH, the keyway and woodruff key is on the flywheel side. The clutch side only has that threaded bendix nut.
robin
618
77
They are a joke! I called them up first of all! As soon as I mentioned the clutch and that I bought it from them. There was no help at all . I asked politely three times for the rear washer I was very polite. He said I could just get a washer and put behind it. Big huge joke. No washers available the guy was crass and no help what so ever. Even hung up on me . Dean can never be reached.
Pmed europorsche914 he gave me the # to his contact Franco Morini 610 562 3155 . Talked to an old man there who was helpful. Ordered up more washers and three brass bushings. The lady that answered the there straight up told me that they had had 4 complaints about Morini USA this morning and that it was important to her to say there place of business had no affiliation. This was well before I could get any word in edge wise. I had not even said a word about Morini USA joke yet!
I truly was polite to the guy when I talked to Morini USA. By the time he got done with me I truly have no problem never giving that place of business a dime again.
Welcome to Herdan Corp.!
I found that Herdan the morini dealer--the old guy is Hermie- i bought a carb and carberetor parts hes super helpful--he works some nights to 2 am and is over 70 !! he seems to know any question you throw at him too. I found the other guy quite terse --hes probably stressed out --overworked or other problems but he must have good days too. Dean uses Herdan too.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
I use Loctite Thread Locker Red 271 and been using it for years. However I still use the blue Looctite on occassion when I know I'm going to removing the nut. The thing about loctite is you need to let it dry to work and the way it dries is lack of air. You can leave a glob of Loctite on a plate for days and it will not dry.
As for my new motor, I'm going to run it stock out of the box. If it studders on the top, then I'll change the ignition and flywheel. Dean installed a new 19mm carb and a new 3 shoe clutch today and swears it made a huge difference. However he made a new manifold because the carb wasn't sitting flat to keep the bowl filled. We're going to do some testing next week and if the carbs the real deal...I'll let you know.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
How many RPMs is the 9.4 Morini you are looking at? You got to swap ignition around? Does it have a different stroke? It would have to I guess?
I think its in the mid 13k range. We've had bad luck with the "so called" better ignition but I'm willing to try it out to see if I can get it to work. If not, I'll be slapping the old ignition off of my 5.8 motor.
The 5.8 and the 9.4 have the same stroke. It's the 11+ hp motor has the longer rod. You would have to add a spacer between the case and cylinder.
I forgot to mention that to remove the red loctite, you need to heat it up a little and it comes off easy.
Dave31
11,199
47
Aztlán, Arizona
I have never liked that play in the bell it never seemed right to me. Not only is it noisy when walking or just pedaling the bike it will make a god awful growling sound when backing off the throttle from full RPM.
It does not do it all the time but during the DR I thought something was gonna let go. I am defiantly gonna do something about it before something gives out and gives me more problems that I cant afford.
Easy Rider
Jan 15, 2008
2,145
7
Nor*Cal
Yeah FR31, Let us know if you find anything to tighten up the bell. I just got done cleaning my r/c stuff off of my work bench and will start taking the 5.8 off tomorrow. Then I'll start ripping apart the motor by next week and inspect the clutch more closely.
