I measured the jackshaft and it measures 7.5". I tried an experiment for the cranks, I shortened them. It doesn't give an advantage on the track, can't use them for starts or getting out of the corners, but I like them.
I mounted the engine horizontal, so I had to cut the down tube, spread the frame apart, weld angle iron to the down tube and seat tube, then welded a mini bike mounting plate to the angle iron. this lowered the center of gravity a lot and it helped with cornering, I also adjusted the rake.
