I just bought the BRP6HIX spark plug and wire for a 49 CC RAW on a 26" cruiser. Can anyone tell me how many more mph I might expect by just adding this plug?
thanks
Showcaller
thanks
Showcaller
Even if the plug had a thousand points,hi, just seen this thread, yesterday i was messing around on youtube, and came across a spark plug called powerstar it has an 8 pointed mushroom, over the usual spark thingy. all 8 spark. awsome. never seen anything like it. not sure if we can get them in our size though, they say more miles per gal. and smoother better performance. I wish they were available years ago when i had a yacht, the spark plugs kept getting lead across the point and cutting the engine out.
Would have difficulty shorting out 8 points on the plug,WHAT!
I switched to the extended reach plug and picked up 10 hp, or was it .01 hp? Whatever it was it worked a little mobettai run an NGK BH6S or a BH7S in all my bikes, gapped at .030.
That's what I'm running except mines a 6 and my engine is a 48cc. That might make a difference maybe.i ran a BP7HS (the longer one) in one of my bikes and it ran worse.
Well, when you consider that the stock plug is in the "4" range of heat going to a "7" is a lot colder plug. With a B7 you need a higher compression than stock. It's a good range if you've sanded the head for more compression, about 8-9:1 ratio.i ran a BP7HS (the longer one) in one of my bikes and it ran worse.
