Ok, new kit. Finally got everything together. Took it out to try it and couldn't get it started.
I pedal up to speed, drop the clutch and it sounds like it's running...but it's producing no power and it slowly bring the bike to a stop and the engine sound dies out.
Also if I release the clutch...the engine cuts. I don't think it's actually running, I think it's just the sound of air being forced through the motor when I dump the clutch.
There's gas in the tank, the cut-off is opened up, the chain has proper tension, the spark plug is installed and the coil is hooked up per instructions.
What am I missing? Should I hold the throttle open when I drop the clutch? Which way should the little switch on the carburetor be (up or down?)
Any other trick I'm missing here? If not, then where should I start troubleshooting? Thanks.
