This isnt the same bike but this is the closest thing i could find frame wise. It has the same exact rear suspension set up, it has the pivot behind the crank case so it moves up to remove shock. I need something that will adjust for the slack that this will build i was thinking a tensioner that was spring loaded so that when the slack comes into play, the spring releases its tension and pulls the chain back into a taught position, just drawing something that works is my problem. If you can even make a rough sketch of something u have that may work i appreciate it.
