Hello Everyone.
I have recently purchased one of the new style CNS carbys but I am unable to tune it properly. Very frustrating.
It starts easily and is tuned well enough for a trip but it has a problem that I can't identify yet.
It Idles fine and I have made adjustments to the idle circuit but when you open up the throttle it bogs down from 1/2 to 3/4 throttle then opens up again to full throttle. Also it seems to take a long time to rev down to idle again although I have reduced this with the idle mixture adjustment.
This carby has a slider and pin which I assume is the problem but I have tried all of the clip settings without success. This carb does have a proper air circuit which premixes air with the fuel leading to and surrounding the main pin/valve.
My questions are:
What does this bogging down at 1/2 to 3/4 rev mean? lean or rich condition?
Could there be a blockage in the internal circuit?
Could the pin have the wrong taper?
Also what about the main jet? I am assuming that because it runs well at full-open throttle the main jet is not the problem.
Any help would be much appreciated
My questions are:
