so my bike started to bog a little and leak from the over flow hose and also the idle suddeny would go out off and on pluss my choke was all jacked up it was making my carb overflow and the motor run leaner when turned on !!!!! the choke is suposed to richen the mix on this carb !... ok easy fix the float bowl needs to be adjusted to close sooner so the fuel wont fill the bowl to the overflow post...thats what i thought the prob was.....
so i open up my carb and i find the float chamber filled with plastic hunks and strands all half desolved and everywhere !!! no way ! my idle jet was clogged with it and it was all over and in every passage !!!
so i clean it up and give it a warm soapy wash and blow out all the ports pasways and jets..............
