i just finished this bike the other day and wanted to share it with you guys. it has an old briggs that i've had for a few years just sitting around not doing anything. i found an old bike at the dump and brought it home, did some welding with some scrap steel square tubing i had lying around, bolted a sprocket (from ebay) onto the wheel, threw on a clutch and there you have it.
top speed was 57.5km/h, but that was before i modified the camshaft. it'll probably do 2 or 3 more clicks now. there's only one brake, but i'm going to put on the front tire from a mountain bike and some better pads to get a bit more stopping power.
this thing is geared reeally tall. at 57km/h it's only turning 2800rpm. still another 800rpm before it even reaches its rated horsepower.
ol'reliable
here's after i removed the "easy spin" feature. what it does is pop open the intake valve during the compression stroke, and while that makes it easier to pull over, it's bad for power, especially low down, so i ground the lobe off the cam.
i'm gonna have fun cruising with this thing. i might even go on a road trip or two. already put 80km on it
ol'reliable
