For some time now I've been thinking about building a gas/electric tricycle from stuff I have left over from other projects and donors. I doubt that I'll actively be building on it much for another year or so, but now is the time to start putting things together into a mockup at least so that I have a better idea of where I'm going, how to get there and what ways I can make rather than buy what I want/need.
Pictured below is one of the first bikes I put together. I was more crippled then from a disease I have called GBS or Guillane Barre Syndrome, which has symptoms like polio. A girl's bike frame was easier for me to climb aboard so I picked one that appealed to me, a 1963 Schwinn American Deluxe, made in Chicago. I rode this bike a lot until it started running rough (I think probably a cylinder head gasket needs replacing) around the same time I was moving into 4 strokes. The bike got stored away and has been neglected since.
I had cool 1942 Schwinn 'The World' girl's bike I intended to use for a trike project, but then gave it away to my good friend Fasteddy for his trike project. I'll use this bike instead. The engine is the bigger China girl, 80cc or whatever you want to call it. I put a pull start on it and it served me well, started easily and had nice power.
Pictured below is the 63 American. Also pictured is a
Golden Motor 36 volt front wheel pancake, one of the earliest ones they sold. I actually had it mounted on this bike at one time with three lead acid batteries on the rear rack. I liked aspects of it, but it did not feel safe with too much weight too high up and inadequate braking for all of the accumulated weight of bike plus rider. I did like riding along with the gas motor and kicking in the electric on steep hills or shutting down the gas motor, and going under electric power more quietly. The gas/electric combination was nice. The weight was a deal breaker. I removed the pancake motor and it has been sitting since.
In the past couple of years I have become enamored of suspension forks. The ride is so much better that I'll never go back to a rigid fork. Following the lead of msrfan and his use of moped forks for his briggs builds, I have done the same and grab one whenever I can for possible future use or to give someone. The one pictured is a German made Sachs Hercules which was intended for a light motorcycle/moped application. I figured it would give me a nice ride, in effect stretch the front wheel forward several inches and give the bike a nice look. I also made a honker of a headlight for it from a Harbor Freight dune buggy light, much modified. The basic light costs about $12.00 and is well made with good chrome... a real bargain. The 12V halogen bulb got removed and I used a cluster of led lights from another good deal at Harbor Freight, a 4.5 volt flashlight that puts out a lot of light. I removed the post mount, drilled two mounting holes so it could fit between the fork ears and have a nice headlight for less than $20.00. If anyone is interested in some how to pictures on the conversion, let me know and I'll post them.
So that's the basic stuff. Now to see if the intended parts will go together...
(cont.)
SB
(cont.)
SB
