This is the Motobike that I got a good deal on:
The nice girl that owned it won it and kept it in brand new condition!
I remember seeing one of these at Wal-Mart a few years back and thinking it would make a great freeride bike with an engine. It turns out to share brakes and rear shock with the Razor Mx500/650 which are heavy duty. The frame is nicely welded aluminum, and the fork, steel.
First thing I did was peel off the X-games decals,and feel kinda bad about it but the replacements will be cooler if I do replace the decals. The thought of blending in with this bike and keeping it low key is an appealing one. With all black fairings it looks more like a mountain bike in the dark than a dirt bike, which I know will generate some confusion even with a license plate.
Depending on the fitment of the engine I might make a mount that attaches it to the frame or the swingarm. The CVT came today and it looks to be worth the price, the engine should be here soon. The dirtbike exhaust came as well and will park the mufflers in between the number plates, which will probably require some heat shielding to not melt. I like the idea of having the mufflers shielded from burning skin and out of view. If they're not quiet enough I'll grind off the spot welds and repack them. On cars I've seen that dual mufflers tend to lower the note of the engine and make it less raspy, so thats what I ordered, and it has an expansion chamber. It's gonna get wrapped so I don't burn myself, because I ride in shorts like a dumbass.
The steel 72t sprocket is very heavy so I'll drill it like a brake rotor most likely. I bought a freewheel that has four mounting holes that match, but it's a POS so I'll try to use the ACS Crossfire I have and mount it to the Sturmey S3X that I acquired a while back hoping that I could make a hybrid hub with the SRK3 on my electric bike and use the best parts. No luck with that, so I have it left over, perfect for this bike!
The CVT will require mounting the engine backwards, as it reverses the drive direction. Hopefully there will be no issues with oiling or the orientation of the carb. I'm planning on making an engine mount that bolts on and integrates a skid plate, since there will be less clearance than a dirt bike without cutting into the frame and welding in an engine mount integrally. This bike will be more for fun and light use, and the engine will be mounted similar to a Puch moped but reversed with the plug coming off the back. The only way around this is a reversing jackshaft setup but I'd rather just keep the chainline clean by centering the output of the cvt with the swingarm pivot, and using pegs. Like my other bikes, I'm using pegs because I'd rather not trash my ankle accidentally digging in. With the trans mounted in an L shape with the engine (not sure if it's possible yet) the pegs can be mounted where the crankcase is on the swingarm by simply removing the one piece crank and using a long bolt, axle, or allthread.
The engine will look somewhat different because it will have the CNC machined head and some other upgrades. $120 off Ebay, not too shabby.
When I arrive at a good looking and reliable final engine mount design, I'd entertain the thought of making more and selling them. These bikes can be obtained off Craigslist or Ebay for cheap, and they're actually really nice for the money. I'm really excited about this because with the CVT and gears it should be able to climb at tree and still get good top speed since these little buggers rev to 11,500 supposedly.
I also ordered an adjustable three shoe clutch since people have had major issues with the springs snapping on the other ones. Of course mine arrived already broken form the manufacturing process, where they peen the cir-clips down that hold the clutch arms, and freeze the assembly and broke a clip. Totally stupid, the manufacturer doesn't understand how this clutch is intended to function, as it is now it would stick and send you through a fence! So I gotta rebuild that, and once the engine comes, replace all of the hardware.
The KTM style gas tank will require gutting the fairings or fitting some old plastics from the MX650, they're yellow, yuck.
My goal with this is to have fun with it and break in the engine, whether I keep it or sell depends on how much I like the OCC bike that I need to finish, once its done. It's really gonna be awesome, a dirtbike style moped/bicycle. If I can find cranks wider than the CVT + engine + pullstart width, then it'll go back to having pedals because I think that two sprockets on the hub might be an option, with a fixed one on the engine and a freewheel for pedals so no freewheel crank sprocket would be required. Freewheel cranks kinda scare me, it's like a buzz saw!
This bike should be ripper, and if I can get it really quiet then it will be nice for some light trails.
