Schwinn Clairmont
KnockKnock
79
CenTex
I like pictures. They have a way of dumbing things down for the most dense of dim-whits among us. ...like me sometimes :)
#1) AGK clutch
#2) Jackshaft of mysterious origin
#3) Engine mount of mysterious origin
#4) SBP shift-kit bottom-bracket stuff
I can only assume that you either used the engine mount from the SBP kit and re-drilled it, or ordered the one specifically for the Preddy, but I'm not sure which. #2 is a jackshaft of what manufacturer or combination of what parts; ie. Are those SBP's bearings rolling a custom shaft, or is it a totally new creation of carrier bearings from a 3/4-ton Ford and sprockets from the AGK kit? Sorry for so many questions, but I'm dying to know exactly how you got this combination up & running. Thanks, Kk
magna_503
251
Portland, OR
didn't have the list with me at work. Just got home from a graveyard shift..
but here it is.
1.) AGK high stall clutch http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=2404&Category_Code=99cc
2.) http://www.bicycle-engines.com/Black-V-Frame-Mounting-Plate-Kit.html
+ AGK motor plate http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=2306&Category_Code=99cc
3.) http://www.usabearingsandbelts.com/...llow-block-bearings-ucp202-10-bulk-sales.html
+ 1 1/4" mirror mount if your seat tube is 1 1/8". I got them for $6 shipped for a pair on fleabay
+ AGK jackshaft 12" and cut to size http://www.affordablegokarts.com/mm...e_Code=A&Product_Code=0500*&Category_Code=PCJ
+ http://www.usabearingsandbelts.com/18m7/sprockets/35-sprockets.html for all your sprockets
You probably want to figure out your gear ratio first, then buy your pillow block bearings + sprockets at once. Shipping is quite spending @ usabearing.
4.) http://www.sickbikeparts.com/catalo...ucts_id=107&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ucts_id=104&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=38&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=66&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=37&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=62&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=35&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
http://www.sickbikeparts.com/catalo...ducts_id=82&osCsid=f224u3vjbfh6r9c1h21h3rpjh3
I think that should set you up nicely.
bedtime
