This was my winter project I recently finished. We've had a few warm days so I had a chance to test it. Very smooth, cruises nicely around 40 mph. Top speed (checked with car speedometer) was 53 mph. I believe it will do better as it gets broken in. The engine is a 70CC. It was way less than a Honda or the Chinese 4 strokes. My Nuvinci hub won't last long I'm afraid using these speeds and torque. It sometimes skips when it gets hot after a long run. I have about 75 miles on the bike by the way. I twisted the axle in the dropouts using one set of locks. I have two on each side now and that seems to be holding. The chain tensioners in the picture have lockout washers that fit over the axle and in the slot as well as one on the outside to keep it from twisting. The twin disc brakes on the front are an improvement over the single but I would like for them (the pads) to be bigger. I will continue to work on this one trying to get more speed and maybe play with some lighting.
PS I know the chain from the engine to the jackshaft is a little loose. I changed the sprocket and didn't tighten it. The sprocket on the engine "floats" back and forth to keep the chain perfectly in line so it doesn't want to come off anyway.
