Finally getting started on the pred 212 build. Prepping the engine for a vert install and mikuni carb, i went ahead and removed the gas tank, carb, and throttle linkage bar (if thats what its called) and now im left with this little pin you can see below. I've been told i need to remove the governor to remove that little pin, the use a screw with some lock seal to cover it, but my question is, is there anyway to remove that pin and seal it with out removing the governor ? If not, then is there anything i should be careful off when removing the governor ?
