I was doing improvements to my little BGF ebay engine. Ordered some SBP Grade 8.8 cylinder studs. Torqued them down into the case then installed the jug and head and torqued the nuts down. Tried a ride, no start and a terrible squeal then the back tire locked up. It appeared that the crank seized.
Upon disassembly saw the pictured penetration into the crank case from one of the studs. Crank was contacting the metal in about 90 degrees of rotation and caused a small scratch on the very outer edge of the crank, not a big deal IMO.
Now, should I just replace the case, or can I Dremel the pooch of metal smooth and try again? Of course being very careful when re-installing the studs. Perhaps only torque them into the case at half spec, then full spec after the jug and head are put on. Maybe grind off a thread or two in the one stud that broke through the case?
And yes that is a less than a quarter inch hairline crack on the pooch of metal.
Also, the clutch shaft will not come out, don't want to beat on it too hard, am I missing something?
Thanks in advance for all your help!!
