With the huge garage cleanup I'm doing all manner of parts and half started projects are coming to light. Among them is an autocycle semi-replica that I started to build using a gen 2 80cc China Girl and a 10 speed Mixte frame.
Mixte frames are not easy to get a China Girl engine into, It can be done, but usually involves spreading the two parallel diagonal frame tubes. Some Mixte frames are easy to modify and need little work, mine wasn't like that at all,- it was a right pig.
Now that the engine is basically able to fit into the frame, the next stage is to proceed with the fakery. Among my English bike bits I've got quite a few Rudge parts, so basically all the modern fitments will be disappearing from the frame and will be replaced with either Rudge or genuine 1950s English parts. This will include the forks, wheels, bottom bracket, chainwheel, chainguard, mudguards, pedal arms, pedals, handlebars, saddle, brakes & etc. Real bikes hold their pedal arms on with cotter pins anyway, so the old 10 speed chainwheel set can go into the scrapbox.
I've found a nice 1950s Sturmey-Archer 3 speed hub (did you know they're all dated with the year of manufacture) so that will be used on this bike as well. The exhaust system will be a faithful replica and therefore should be quiet even if it doesn't do a lot for performance. I'd like to try using a Villiers carburettor and air cleaner too.
It's my intention for this bike to look old, so I'm not going to re-paint anything. All parts will be left in their original faded and rubbed paint, cleaned very well and then after the fitting of NOS Rudge transfers (decals) waxed using something like 3M Marine Wax or similar.
Three problems are going to make this awkward though, all the Rudge forks I've got are black, and I'm going to need to solder up a repop autocycle petrol tank and engine shield from scratch. I'm sure finding a match for the blue paint on the Mixte frame won't be too difficult, - only then I'm going to have to find some way to age it.
Theoretically this is supposed to be a quick project which will both help to clean up the workshop by using up spare parts and also give me some useful wheels for local journeys. Hopefully it will prove to be the case.
