Please help! I am new to this forum ad motorized bikes in general. I have a Grubee SkyHawk GT5 66cc 2-stroke engine. With the regular carb not the CNS specialty one.
Anyways when the clutch is pulled in it idles at a very high rpm. However when I let the clutch out it drops down to a normal average rpm. It works fine until about mid-throttle. Then the engine boggs out. If I drop the throttle back it works fine. It didn't use to do it. My dad has been the one that has been modifying the carb with the idle adjustment screws.
I have tried to read up on it but can't find anything in particular on this problem. I think I may have to turn it to less fuel, more air. If that's correct or incorrect please let me know. Also should I be running a more lean gas mixture? Please help. Thanks in advance! If you need more info let me know. I will try to get back to you as fast as I can.
