Full Suspension With CVT
I've been working on this build for several years in my head and at last she's a reality, a full suspension bike, with a hot motor, running through a CVT. I must say, I'm very pleased with the results so far, although I've only had several shakedown runs. That will change tomorrow and big time on Sunday. If everything goes well, I believe I will crossed the line between motorized bicycle and moped. Thanks goes out to Neat Times for his inspiration and consultation on this project.
http://motorbicycling.com/f36/cvt-rack-mount-7265.html
One day a little over four years ago, I found myself staring at a weed whacker engine and a bicycle and pondering, could this work. To make a long story short, I bought a Staton friction drive kit with a Tecumseh TC300 and made my first build. About a week later, I built one for my wife and we began riding together. Always looking for more speed and power, I swapped the TC300 (junk) for a Mitsubishi TLE43 and found what a quality engine was all about. Rough roads were wearing a little thin, so again I upgraded to the Mongoose full suspension and later to a Staton Chain drive. The little lady went through both TC300's so I bought the Chung Yang R460 for me and gave her the TLE43. I created a two speed on the Staton box and it worked well but that CVT bug was always in the back of my mind.
For this build, I wanted speed, power, quite and a smooth vibration free ride. To that end, I used the CVT rubber mounts and added rubber isolators at all other mounting points. The power is routed from the CVT through a 14 tooth sprocket, down to a 72 tooth freewheel sprocket on the wheel. The chain is 8MM, which seemed to be the easiest way to go. I bought a scooter muffler but wasn't happy with the chain saw sound. I gutted the muffler, added about 4" of length to the housing and created a straight through glass pack, with a spiral baffle inside the the core tube. Since I had been running a Staton chain drive, my Staton rear hub had a 16 tooth left hand freewheel. I just pulled down the bottom bracket and swapped the pedal chain to the left side. A quick idler roller and it works like factory, single speed of course.
The bike is quite, accelerates like a car, eats hills and hits 35 mph at 6800 rpm. Don't know about top end yet but the R460 will wind out above 11,000 rpm. I hope I'm back after my hard runs with good news. I've included pictures of the bike, before and after the build.
