Pictured below are a couple of battered up gothic fenders from a 1940 Elgin, to be mounted on a 1939 Elgin. I know, they look pretty rough and are going to be a challenge. In both pictures you can see where the metal is fatigued and needs to be repaired. Especially considering they are going to be subjected to the rigors of a HT engine vibrations, I want to be sure they are sound. These fenders are heavy, with good metal in them, but they are old and have been abused. My question is in how to fix them. I don't weld and that kind of seems like overkill anyway. I am pretty good at soldering, with much experience joining copper pipe (ran a resort with lots of plumbing work) and soldering lead (had a stained glass shop at one time), but that is it. I did manage a couple of throttle cable modifications with silver solder, my only experience with silver. I was thinking to first clean up the fenders by stripping them, which has to be done anyway. The repair areas would be subjected to the wire wheel and thoroughly cleaned down to bare metal. I would use my propane torch at fairly low heat, silver solder flux the repair spots and apply silver solder, with just enough heat that it flows into the fender and is not just sitting there in a blob on top. Am I on the right track? Will this make a good repair or am I wasting my time? Is there a better way to do this? Is silver solder necessary or could I use a less expensive solder. I'm spending a lot of time and effort on this old bike and want to do this part of it right. While I want it to look good, I'm more concerned with it being sound and riding safely. I'd like to think this classy old bike is going to be around for a very long time. I now have the frame stripped to bare metal and am beginning on the fenders, fender skirts and chain guard. Thanks for any suggestions.
Silverbear
Silverbear
