Yeah Trey, I just answered a guy that wanted to know if he should grease his bucking bar and bearing before installing, and what kind of grease to use. I told him about some boat trailer marine wheel bearing grease that a friend left in my shop. BEST CRAP I EVER USED. Good and sticky, Sheds water, Stays where ya put it.I also have something in my memory about lithium having 'water retaining' properties... but don't quote me.
I can not say enough good things about 'super web grease'. Man that stuff sticks, and stays. It's made by a company that makes a chain lube that I used to use. Buuut, it's a buck fifty an ounce.
In my opinion, marine bearing grease does just about anything you need a grease to do.
having done the job without a cone wrench I concur.You should also invest in a cone wrench. It will make adjusting those bearings much easier.
if wheels had standard hex bolts in place of cones, wheels would be WAY too wide for any good.h
is there a good reason why cones don't just have normal hex-bolt heads on them?
Yup Dave, Been making my own cone wrenches like that for years. works well for me too. And ya almost cant get by without them.When it comes to cone wrenches, I just use a old pair of 15mm wrenches and grind them down on my grinder. Works well for me.
That was the idea of ceramic bearings because folks swore water ruined any steel ones. Ceramic did not proove cost effective in the long run IMHO however. On my sealed bearings I have to take the hub apart remove the seal with a sharp pick tool. Smoosh as much grease in as possible and put the seal back on. Don't trust that the manufacture packed those full of grease righteously ether. Pull many a seal on a new bearing to be disappointed....Of course, sealed bearings eliminate the need to grease or adjust your hub, that could also be an option to consider
So the the bearings have black colored seals? Those come out easy peazy IME. I have to repack my sealed bearings on this bike every 900 miles or so for the rear wheel to say I am on top of them. Then again I am sporting about 13 hp on it. The bearings in the rear hub are just ordinary bicycle bearings. Wish it was a little more heavy duty.I popped one of the bearings out of my rear hub. Seal didn't want to come out and I didn't want to damage it. Also could see and feel grease around the edges of the seal. They're pretty decent quality, 6200 series. 10mm ID, not sure of the OD but they aren't very big. I'm just gonna trust that they'll be Ok.
