So this kit is the one Im gonna try , so what chain fits this sprocket ? Thanks for any in put .
Ditto: #41 will serve you well and fits most any sprocket. The Chinese equivalents won't deliver the same performance. Especially the kit supplied 415 chain.Run #41 chain and you can get sprockets for it. Its the same pitch,it is heavier and will work on your sprockets..................Curt
Leo,there must be some fairly substantial differences in the housing of these motors. several of you have mentioned using tsc41 chain, but it drags the gearbox like crazy in mine.
Maybe take a look at this old thread which addresses that problem.yes, i do.
sorry, suppose gearbox wasn't the best word to use, i just meant the drive sprocket's housing assembly/cover. #41 chain drags inside it on mine.
Yes it works fine on the kit sprockets,just a bit wider but no problem.Curtis , 2 door , so your saying that a 41 chain will work on my 415 clutch teeth and the kit hub sprocket teeth ?
And not being versed in gear ratio was wondering what size sprockets to put on jack shaft for top end speed ?
