I have a five horse briggs motor on my bike and a aluminum wheel set with a shimano cbe110 rear hub. My question is can I weld a flange on to the hub?
I'd explore some of the sprocket adapters available. You should be able to get almost any size sprocket to work with one. I know they aren't cheap but they do work well.I am mounting a sprocket.
Of course you can always use the 'rag-joint method. Installed correctly they work just fine. I'd just hate to see you take a chance on damaging your hub by welding on it.
"Rag Joint". This is the 2 stroke kit supplied method of attaching the rear, driven sprocket to the rear wheel/spokes. It consists of a sandwich of sprocket, rubber, spokes, rubber, metal plates and the nine fasteners that hold it all together.What is the "rag joint method"?
