Hi everyone,
As many are aware the Q-Matic is available to fit many motors including the HF 79 CC motor. The Q-Matic has been tested on the 79 CC HF motor and worked 100%. We tested the drive system last year, and many rode the proto-types at Lewes, DE.
EZM will assemble a special assortment of the Q-Matic kit for the HF motor.
Kit "HFA" will only include the Q-Matic drive.
Kit "HFB" will include the Q-Matic drive and the special tuned flex pipe option to solve the "hot" exhaust pipe issues.
Kit "HFC" will include the Q-Matic; flex exhaust system, & HD #41 rear chain.
All "HF" kits will include a template to allow the drive system to be tilted to fit different bicycle frames.
All "HF" kits can be ordered [no extra charge] with alternate ratios, therefore can be geared low or high depending on rider & terrain. We can set the drives to pull up the side of a building [LOL] or try for the Bonneville top speed record.
The Q-Matic is so well designed [spring loaded idler] that the custom front drive pulley can be exchanged [extra cost] for an adjustable version to allow quick-change ratios.
The Q-Matic can easily handle motors with more torque because of the suspended Max-Torque clutch and the massive drive shaft bearings. During earlier testing we found attaching bearings directly to the drive plate didn't allow enough support to handle many "torquey" 4-stroke motors and ended up with output shafts "tilted" and created extra stress on the bearings, chain, & belts.
By design, the Q-Matic is approx 2" wide, and the MaxTorque [special edition] clutch is located where it is easy to apply lubrication [recommended by Jim at MaxTorque] when needed. By design the Q-Matic does NOT have the MaxTorque clutch mounted on the motor flywheel [shaft is too short on some motors to correctly install the wide MaxTorque clutch], and therefore the belt drive offers some buffering [less vibration & wear].
Normally shipped within 48 hours of order, hopefully in the near future we can reduce the shipping times.
Contact any EZM dealer for more details & prices.
Because of volume purchasing we can offer our drive systems at prices below most, if not all, American companies.
Have fun,
Have fun,
