Problems with spark plug & piston
bucukkarut
indonesia
Hi all,
I am Bucuk from Indonesia
I've been having problems installing my new China engine.
- When spark plug is disconnected from engine, the back wheel and the piston move
- But When spark plug is connected to engine, the piston does not move and the back wheel does not move too.
please help me..:-||
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Welcome to the forum!
Sounds normal, it's because of the compression. Once you get everything installed, and pedal the bike to start it, it will move. Be sure to pedal at a good speed before releasing the clutch lever.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
The clutch cable must be installed and adjusted properly before you try to move things. If the clutch is engaged, and it probably is, you are fighting engine compression. Remove the plug and there's no compression.
Finish the installation, adjust the clutch cable and things will work.
supercub
56
New London, CT
Check to see if your piston is hitting your spark plug. Look at the plug- is ithe tip getting bent in any way? With the clutch in, the bike should roll around. Clutch lever not pulled, the engine will turn over when pedaled but you will feel the compression of the motor I usually have my right foot up on the pedal and crank it down hard just as I release the clutch lever.
