http://www.ebay.com/itm/Briggs-Stra...098783?hash=item3ab0f7471f:g:VHcAAOSwMmBV5gfy
Saw this Briggs electronic ignition part on Ebay. It does not include the magneto and looks as though you reuse the regular one, but add the module to eliminate the points. Note key shown along with other parts.
Many others I've seen do not show a key.
Without changing the keyway slot, a different key has to be a smaller key width.
With the key being somewhat smaller to offset the flywheel some in relation to Top Dead Center on Compression Stroke as maybe required for change from regular to electronic ignition, I have a question maybe you can answer.
The offset I would guess would only be kept from having play, by the flywheel being tightened down. And also this. If there is a slight space with the thinner key in the keyway, does the flywheel go back on essentially a little bit the opposite of rotation of the crankshaft? If so, then I could see as the engine turns it keeps the flywheel from changing position with relation the the crankshaft.
Only if there is a strong engine braking and the tightness of the nut holding the flywheel gives way and loosens the offset would be the opposite way, messing with the electronic ignition more than a regular key would.
That is as the engine turns, there is a small space between the key forward edge and the forward edge of the keyway slot on the crankshaft for the flywheel. That space has to be kept that way? This to ensure that the magnet on the flywheel is slightly advanced in relation the the magneto laminations to make up for the difference in the delay of the electronics in the solid-state module conversion kit.
MT
