I will be using Amsoil dominator because people reported it being the best in preventing piston wear. Amsoil makes the best synthetic oils, although they are not cheap, the ratios for Amsoil do not need to be like super low. With that oil an 80:1 ratio is considered good.
I imagine your engine was smoking.
Why is the Tanka so cheap on amazon?
By the way I did not find it on amazon.
Does the pocket bike engine Carburetor and exhaust work with the Tanka?
Hopefully extra money won't need to be spent on that, because for the tanka carbs and exhaust are probably expensive. Or does it come with it already?
Also a gearbox for reduction. Or does it have one built in? So a clutch is still needed if it does not come with one.
Most of the money I spent went on accessories such as cable, throttle, sprockets, fuel etc.
Making mounts for the Tanka shouldn't be hard if it fits inframe.
Let me know how strong your tanka runs when you mount it on and how fast you will go. Also how loud it will be.
Reason I ask to let me know is because I want to know if power is worth sacrificing for reliability.
Both engines can be reliable and both can fail (Although Tanka is probably a little bit more reliable), but only one (Tanka) has less power and the other has more power.
