This here is the mod 4.
2008 schwinn panther aluminum alloy cruiser
67cc grubee
dellorto carb with handlebar mounted choke
40 tooth aluminum sprocket (massive weight savings)
sturmey archer 90mm front drum + dyno powering...
...German made supernova led 800 lumen lighting system
rear clincher brakes
sbp dual pull brake handle
sbp low profile air filters
sbp expansion chamber, tuned exhaust, exhaust wrapped
sbp engine mounts
sbp engine hardware replacement steel, uniform hex heads
iridium spark plug
fat 2.125 racing slicks
lots of black paint
*and a pos chain tensioner. fabricating new solution for mod 5.
The expansion chamber and carb function in unison to maximize fuel-air mixture and revs. 35mph uphill, redline 42mph level, fastest down hill bomb run, 52mph...coasting engine off. Charges up hill with the choke in 75% at high revs, pipe tunes-in tons of torque.
so far, I have 800miles on this engine, I get about 150mpg. Nothing but fun.
67cc grubee
sbp engine mounts
iridium spark plug
lots of black paint
