Dropped one of those tiny clips for the piston into the crankcase. Thought it was no big deal but I ran it and now the piston is stuck in the cylinder cuz that clip is lodged in between them. Won't come out. F me. Tf do I do?
You'll have to replace the top end, piston, cylinder and rings. Use a wood block to drive the piston down and to tap the cylinder off. Be sure to remove the engine and wash out the debris from the crankcase.
I would use fuel mix, I've used a old tee shirt streached over a 5gallon bucket to pour the debris on, that way you can see what comes out of the engine. Let it air dry open for a while after and it will dry out.
