Oil Ratio
20:1 or 40:1
  • Total voters
mapbike
5,502
109
Central Area of Texas
40:1 should be just fine.
I've personally run several different oil fuel mix ratios over the years wndnas long as the carb jet is right so the engine doeant run lean on gas, youll be just and if you have the stock main jet still in the kit carb. you should be any where near to running to lean.
Greg58
5,353
2,575
Newnan,Georgia
I run 32/1 also, I have tried 40/1 with no problems, all my other 2-cycle engines run 32/1 so I switched my bikes to the standard mix I use in everything else.
  • Like
Reactions: mapbike
