I have built all my rhino drives using a ten inch schwinn type rear wheel assembly. Today I am going to build one with an eight inch izip rear wheel assembly. I am going shopping for parts in a while. I have most everything I need laying about.
The major item on my list today is a foot of 1 1/4 inch heater hose. The wheel had a solid tire on the rear, but alas I could only scrounge a tire with tube. So it is drill the wheel, not something I want to do, or buy a piece of heater hose to fill the tire. A drive wheel tire has no real downward pressure so the heater hose should keep it from collapsing. I have no idea if it will work or not no one I know has ever done it.
I want to do a few things different with this build. I am going to cut a groove in the frame of the drive for the wheel like the dropouts in a bike frame. The reason is so that I can weld as well as bolt the frame together this time. If it works okay I will probably retrofit the other drives that way.
Otherwise it will be just a matter of matching the sprocket on th rear wheel for max efficiency. The motor is way, way over powered for the rear wheel. I think it is at least twice the wattage before i jack the voltage. With that the bike should run three times the power of the original scooter.
