M martin tucker New Member Jan 21, 2021 4 0 1 57 Jan 21, 2021 #1 this is my first build and its a cranbrook with a 53 cc 4 stroke but my problem is pedal hits motor how do i fix this problem
wrench Well-Known Member Aug 20, 2019 766 1,057 93 So Cal Jan 22, 2021 #2 You need to use a wide crank.
M martin tucker New Member Jan 21, 2021 4 0 1 57 Jan 22, 2021 #3 This one is a one piece deal are they a conversion for this
C Choochoo_nesby Member May 22, 2020 68 42 18 39 Jan 22, 2021 #4 They have kits where you replace the whole thing, google or use one of the sponsor links. Good luck. Reactions: martin tucker
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Mar 20, 2008 7,276 1,819 113 Los Angeles, CA. Jan 22, 2021 #5 I prefer to heat the crank with a torch & bend it out just enough to clear the engine , then heat & bend the ends to make the pedals level again. Reactions: Tom from Rubicon
M martin tucker New Member Jan 21, 2021 4 0 1 57 Jan 22, 2021 #6 Venice Motor Bikes said: I prefer to heat the crank with a torch & bend it out just enough to clear the engine , then heat & bend the ends to make the pedals level again. Click to expand...
M martin tucker New Member Jan 21, 2021 4 0 1 57 Jan 22, 2021 #7 thank you i was thinking the same thing its not hitting that much
