need ring job low compession
Mobbin'Deep
118
Far away from home
really easy bro, remove nuts on the head, slide the head off, then the cylinder, CAREFULLY dont let the piston slap the case. Pry the rings off with a flat head, or needle nose. Install new rings, there are little pins in the piston to align the rings. Reinstall everything with fresh gaskets, and use some oil to slide the piston in the cylinder easily.
