OK the spokey dokey drive is basically finalized. I lowered the rpm to the roller by a reduction of 1.75. I had originally designed the drive for a small roller and overdrove the engines out put as I was initially thinking the Maytag would only turn around 2000rpm(turns 2900 now) and I needed more than that at the roller. This did not work with a 2.5" roller.
The reduction now allows full usage of all three gears. First is good for 10mph, second 15mph and third about 23mph. The hub works great shifting fine through the gears, with clutching in between. This thing is now a very cool leisurely ride.
We have been having spring showers and the roads were wet, a perfect time to try out the wet drive capabilities. It did very well, driving nearly a 100%. If you got slow in a gear it would slip a bit until it came back to speed. A normal FD with anything less than a grit roller would not have done nearly as well if at all. The current tires are common cruiser with continuous tread. If this had been a block type tire it would have driven positively no matter the conditions.
Now all it needs is some riding to see if the Loctited spokes stay tensioned. If so its a done deal.
Now for the water cooling madness!
Thanks again SB for the hub!!
