Gasket matching the case to cylinder helps smooth out flow in your transfer ports and is extremely easy to do. It's also safe since you're not changing port timing so there's no risk of screwing it up (unless you go crazy with the grinder)
Start by tearing down the engine and splitting the cases.
Then use a fresh gasket to scribe your ports. (I use marker on the metal to make the line show easily)
Then use your dremel to remove the metal to fit the scribed line. Blend it down into the case a bit and be sure it's all nice and smooth
That's all there is to it! I also blend the blunt edge of the cylinder casting to a sharp edge which also improves flow.(pic next post)
