I heard you mention Briggs Easy Starting maybe Easy-Spin Starting is what you saw. I'm not sure if my Briggs 80202-0430 is using this innovation as listed in the wiki from Briggs below.
I just know that my Briggs was from a Flea Market for cheap ($10) no carb and I over the years changed things thinking I was making it better.
It all came to a crux recently. That the last thing I did was to adjust the intake valve that was allowing pressure out during the compression stroke. While it let pressure out the intake port also wetted the air filter, since I was using a carb that was not like when I started out with an oil bath type air filter.
Now as of recent if I followed instructions to set the valve/tappet gap considering or not if this engine has Easy Spin, it was still going to allow pressure out on compression stroke.
I have another new intake valve if I need and decide to go by the instructions and redo it again, but it has much better compression and runs well. It unfortunately or fortunately had idled with the cheap Briggs clone carb that has no adjustments before I set the intake valve timing to get better compression.
Now I have a cheap Tecumseh Clone Carb with all adjustment low and high speed needle valve adjustments and a matching filter housing and it all is ready to test quite soon. I'll let you know so if you decide on using the Tecumseh or Briggs engines you have with a carb like what I got.
I know I have heard of compression release, that is done manually and or like with centrifugal forces with mechanical weights, but if you see what Easy Spin is, I am concerned it is not as good an the engine power (compression) after starting is less for the same displacement from the other compression release methods that cease after starting.
I have all things ready to test my engine/carb out just did not have time last to put the gas tank back on as I was working on the bike.
I looked at the past pictures of the sheave and the beefy looking hardware mounting it to the spokes. Let's see this marvel of yours come together, cheers!!
http://en.wikipedia.org/wiki/Briggs_&_Stratton
Here is a link for Briggs & Stratton.
Easy-Spin Starting – This compression release, implemented as an extra hump on the intake lobe of the camshaft, was introduced in 1961 to reduce the effort required to start an engine.[10] In 1982, a new U.S. federal safety regulation required lawnmower blades to stop spinning within three seconds of the operator letting go of the handle. The least costly, most common way of complying with the new regulation was to put a flywheel brake on the mower engine, to stop the engine (and therefore the blade) immediately when the handle was released. Briggs & Stratton engineers found engines with the Easy-Spin camshaft were unacceptably difficult to restart after being braked to a quick stop. The Easy-Spin lobe hump was moved to the exhaust valve, but this reduced engine performance. The intake-side Easy-Spin remained in use on Briggs & Stratton's engines larger than those used on mowers subject to the brake requirement, but was discontinued in 1997 due to tightening emission regulations.[11]
http://motorbicycling.com/showthread.php?t=29678&page=17
Bottom of page on post #170 has 5 pictures of the new Tecumseh Clone Carb and Air Filter Housing attached to my intake manifold elbow part and bowl leveling adapter between the parts.
MT
