ingredients- 1 piece of yellow scaffolding that fell off a truck, 2 bikes, 1 snapper rear-engine lawntractor. i need alot more odds and ends but its coming together. ANYONE BUILDING TRIKES---ive seen stock live axle trikes on this site (the rickshaw)the trans is a peerless 700, if you want to make a live-axle hauler, or live axle beast in general, these trans's are the way to go. vertical shaft engines are super-common/almost useless, but the peerless has a vertical input shaft, and a horizontal chain-drive output shaft.you could even use HONDA motors from the push-lawnmowers that have a belt/clutch engagement.cant use a normal lawnmower engine because it wont run without the blade,the spark timing is advanced to make up for the weight of the blade.the peerless can take up to 20 horsepower, and you can shift on the fly, amzingly simple to dissassemble and clean, if you want it to last clean out the grease, and fill it with gear-oil.if you had a live axle trike with a fixed sprocket you would even have reverse. i've never had a kit-bike but from what i've seen they have a dry gear-reduction-box.....very loud, drill and tap a hole up top and bottom then plug them so you could fill and drain oil?you wouldn't need much oil, and it would make them last longer, run quieter. someone should try it.....its probably been done.
