I've been looking through different vendors offerings for a good looking 4 stroke HS air filter... not plastic,. but I haven't found anything yet. Anyone know of source?
Silverbear
Silverbear
How about a bigger picAffordable Go Karts - Home page - AGK - http://www.affordablegokarts.com has the velocitity stake under airfilters gx160 gx200.You will need to get 2 long screws and the air filter is from Ebay Item number: 230496571789.
Take a look at my avatar.
MotoMagz
How did you almost lose a finger... from a cut or what?I had both the heat sheild & the shroud removed and figured I better put em back on. I would rather have a running bike than a non running bike that looks cool.I was afraid I would cook the valve.An I almost lost a finger with the pullstart shroud removed.
Didn't mean to enlarge the pictures that much!!
When you remove the shroud the flywheel is in the open .I was looking at something while the bike was warming up and in went my finger.Nothing bad but enough to realize it was needed for saftey reasons.How did you almost lose a finger... from a cut or what?
SB
That's disappointing cause it sure looked nice without it. I've got this thing about plastic on a motor. It just doesn't fit visually. At least the air filter is doable.When you remove the shroud the flywheel is in the open .I was looking at something while the bike was warming up and in went my finger.Nothing bad but enough to realize it was needed for saftey reasons.
MotoMagz
