Yesterday I noticed that my bike was running a bit too well. Too much power and too much revs. I should have stopped, but I was a long way from home. On the way back I noticed a fairly randon "PING!" every few minutes.
When I got home I locked the clutch on and let the bike idle while I looked for some starter fluid to check for an air leak. The motor gave one last ping, which was enough to stall it.
worried about doing any more damage, i pulled the motor and stripped it down.
What I found... the head bolts were loose and the cylinder walls had numerous shallow gouges- but the rings were intact and did not show any signs of "burn through". Also, the piston cycles freely enough to spin the motor with thump and forefinger. Basically, it did not look great but it did look like it should run.
Then I opened the clutch cover. FULL of rubber.... and when I blew out the rubber I found a loose hunk of metal about 1/8" by 1/2" that had been bouncing around in there. It appears to have torn up the friction plates as well as having caught in between the gears several times (the loud ping!)
My question is thus- should I trash this motor, rebuild it or just put it back together and see if it runs? It was running right up until I took it apart, but i wonder if the cylinder was on its way out? How much of a gouge can the cylinder wall take?
