Okay, last i posted my 33 Poulan Friction Saw was down because the 5/16 threaded end of the Saw shaft broke off while tuning it with the 1.5 roller on it.
So, i welded a reverse 3/8 threaded rod into a 3/8 ID bung and sleeved the other end of the bung over the existing Saw Shaft and welded it up. The hard part was getting the threaded shaft to weld on true and not lopsided.
I changed my lift to a lever which seems to work out great, thanks to the help of Deac, 5-7Heaven and Shoes. I first had a cable lift using a brake lever but it felt like i was lifting a ton of birck. I opted to try out a lift lever in which I welded a 3/16x3/4x18" flat bar above the pivot point on the engine mount and made a latch hook, mounted to the seat post sleeve, for the flat bar to rest on. The flat bar is thin enough for it to flex side to side around the latch hook so i can easily release and engage. I diengage before hitting a red light, then peddle a couple times to get up to about 5-8mph then reach down and engage the engine to contact the tire. I used 5/8 spring mounted from the seat post sleeve to the engine mount which keeps the engine lifted off the tire when i disengage. I welded two stop tabs to keep the mount for kifting to far off the tire. One tab on the pivoting mount and one tab hanging over off the frame to contact the other and keep from over pivoting. Which you can see in the pics.
Another problem i had with the 33 Poulan Saw was that it would overheat and shut down after about 10min. of riding, then id have to wait 10min. for it to start again. I tuned the H screw so it will run Richer which i hope isnt to rich now. But i'd rather it run rich then to lean. I also dropped my cruising speed down to 20-24MPH rather then trying to keep it WOT at 33mph. At 20-24mph it cruises right before it hits the powerband of the 2-stroke engine. If i gas it into the powerband i can feel alot of vibration on the lift handle onto its resting hook. Im going to try some rubber and shortening the friction rollero see if it eases the Vibes. Its definitly has a bit lose of power since im running it richer now but I don't want to hassle with it over heating.
On the BIG HILL on my commute, i definitely have to peddle assist but i could use the workout anyways. It does feel like it starts to over heat or lose power when i get close to the top, But like i said its a big hill. One thing i do to put less strain on the engine is shut off at all red lights and downhills. When light turns green i engage the roller and jump start it once i peddle up too 5-8mph.
My 32oz. Premixed Gas can worked out great and i estimate gets me about 40-45 miles @ 20-24mph. I also estimate a total MPG at about 170MPG at a cruising speed of 20-24mph. Not Bad.
It would be nice to have a GX50, but until i can afford one and or my 33Saw blows, it will have to do. Im going to keep my eyes open for another $50 chainSaw maybe for the Front wheel.
This was alot of work, but thanks to everyones help the next one will be cake. Sorry for so much info but maybe someone can take something from this and i'd be happy to answer any questions.
OH YAH, One more thing, Wal-Mart $20 Bell Gel Seat...SUCKS!!!! should have saved my money and invested in something worth it. Suspension post is my next addition.
