gas in air filter
kr632
77
buffalo
is this normal? i have had two bikes and both did this and my friends does this too. it seems if you dont drain all the fuel out of the line it drains out of the air filter
Venice Motor Bikes
Mar 20, 2008
7,271
1,810
Los Angeles, CA.
Does it flow out of the filter real fast? or is it a drip or two over a long time??
If it flows out real fast, you have some dirt or something stuck in the inlet needle.
If it's a few drips over a long time, that's normal!
I hope this helps.
kr632
77
buffalo
it is a few drips here and there. but the foam filter is soaked in gas.
Thank you
bairdco
a guy who makes cool bikes
Aug 18, 2009
6,537
264
that's normal. the "element" if you want to call it that, soaks up fuel, and over time, it'll drip out. i normally take it off and clean it out with carb cleaner every other week or so. if it gets too clogged, your bike will start sputtering, because it's not getting enough air.
kr632
77
buffalo
thank you.
