I have a 6v light. I would like to hook it up to the white wire on my Chinese kit. It lights the bulb for a split second but naturally acts like a kill switch. I know there is a way to wire it ( probably with resistors) so that the light will stay on without grounding the engine. I was told once that with a couple of components from radio shack it was possible to charge a battery. If this is possible maybe I can just illuminate a bulb or two?
Can anyone tell me if there is a wire I can hook up to that will complete the circuit without grounding the coil?
Thanks everyone, I have used a lot of advice from the forum.....what a great help you all have been.
My shift is changing at work and I will be needing lights for a little bit each day.
Thanks again,
Thanks again,
