I think I finally got it right. The go-kart caliper came sooner than I expected. They would like for it to be full-floating in transverse slots, but I decided it wasn't necessary if the bracket has a bit of flexability. I selected a long piece of 3/32" sheet metal(approx.) for the bracket and welded it to a half-tube that fits the upper 1-3/8" fork leg tube. For a template I used a campaign sign from Jim Bridenstine's Rep. campaign. Great stuff and his are mostly white. The half-tube is secured with SS radiator clamps. I origionally intended to make the bracket from block magnesium, but diidn't want it rigid nor the fire hazard associated with machining it. It seems to operate with running clearance and clamps up with little movement. I got to use some hangar-queens like the hand held power band saw in the vice to finish the cuts on the bracket I couldn't complete on the chopsaw freehand. Also the bike brake cable clamp was a bit small for the 0.065" cable so I "drilled" it out with a conveniently sized carbide burr in the Dremal. Also the ultra-hard lever on the caliper which wouldn't quite receive the cable clamp and drill letter "i" wouldn't cut it. (literally) I don't think it would lock the wheel, but who cares? I is a very good brake that brings to my attention I need to go to a good bike shop and get a set of compatable bearings and races The return spring is hooked to a hole in a washer on the axle. The cable housing has clear vinyl tubing on it to protect from water as it is in not the greatest condition. I may have the bracket powder coated silver or yellow later. For now may just spray silver wheel rattlecan on it.
