I was getting too many lumps on my 77 yr. old butt, so decided to finish the springer fork for my 6-1/2 HP 3-speed Rollfast. I may have opened a can of worms though. First thing that happened was the handlebars have an enlarged knurled place for clamping and the piece of steering stem I welded on was thicker than the rest of the fork stem. That meant find a proper goose-neck, which turned out to be a bike-cross unit. A 4-bolt cutie, but for 7/8" bar. Ground down the large part only to find out it wasn't a sleeve, but an enlargement. I can save it with a bolted insert later, but for now I have the bike-cross bars, which aren't to my liking., So far, it doesn't seem to have much action, so tomorrow I will ease the shoulder bolt pivots and see if that is the problem. I don't have a ready idea of how to stick a front brake on as the wheel travels up and down in the forks. I guess a Schwinn front drum brake might be ok but as I remember, they aren't too whoopee. Also a fender will be a challenge to mount. At least I can return to the original rigid setup. The flat stock (eg:links, spring perch) are 1/4" thick. Both forks are bent back a bit which serves my purpose regarding trail and rake. Was surprised to find the front end lower, as indicated by side stand too long. I will decide if this is a keeper before I shorten it or get the forks powder coated.
