Good evening everyone. My name is Adam, I am 22 years old and I am currently seeking advice on my first build and whether or not a build would be a possibility on my current rig which I have right now.
Given the measurements of my ride (which I will post below shortly), I am not entirely sure if I would be able to mount either a 2 Stroke or a 4 Stroke engine. In either case though, it all comes down to what can (or will) fit on my rig which will ultimately determine which direction I go towards the end of all this..
My current ride is a 2007 Raleigh Venture 3.0 (Factory Condition to the best of my knowledge) which was purchased for me as a gift some 5-8 years ago. This bike has served for me as a form of dedicated transportation for years now, and I am eager to find out if I will be able to improve my overall driving experience on a day to day basis.
So, without further ado, let us begin.
With my ride being a Raleigh, I noticed that the biggest issue I was (and am) going to face is the odd size & shape of the Down Tube on my frame. If anyone of you here have ever owned a Raleigh, then you'll know that their Down Tubes usually take the shape of a sideways oval at the bottom of the frame connected into the Bottom Bracket, and then transition to an upright facing oval where they're connected into the Head Fork.
Note: These measurements were taken from the inside of the frame to better get an accurate figure as to how much space there is between each point of the bike's frame.
Measurements are the length of the Seat Tube, Down Tube & Top Tube.
The Down Tube is the part where I feel will be the most tricky.
The base of the Down Tube where it meets the Bottom Bracket measures 2.5" - that measurement is while looking down on the tube from an areal view. When you near the Head Fork while following the Down Tube, the measurements change to 1 3/4" (again, this is while measuring it from atop).
When you look at the Down Tube from the side, the measurements at the base of the Bottom Bracket is 1.5", where as at the top of the Down Tube near the Head Fork, the measurement is 2 3/4".
Here's a sideways shot of the Bottom Tube to give you a better idea of what I'm referring to.
Another issue I realized I was going to endure was the fact that the rear brakes are wired into the bottom portion of the Down Tube. So, if my bike would be able to have a motor mounted to it, I would have to drill through & around the rear brake lines to make sure I avoided damaging anything important.
Picture taken near the Bottom Bracket:
In addition to the measurements of the Down Tube, my Top Tube has a consistent diameter of 1 5/8", where my Seat Tube has a consistent diameter of 1 1/4". So I'm not sure if I would face any problem there either when it comes to managing a build.
Obviously, I would prefer to use my current rig since it's a $300+ bike and has been good to me in terms of quality and life consistency. However, if it will be nearly impossible to use this rig in my current build project, then I might have to wait until I can afford to buy a new ride altogether (perhaps a Beach Cruiser) and build my ride on that one instead.
In any case, I thank anyone who can offer me some insight as to what they feel will & won't be possible in this upcoming build of mine. I hope to hear from you all soon & look forward to getting this amazing project underway ASAP.
Thanks again!
Sincerely,
Adam P.
Thanks again!
Sincerely,
Adam P.
