Hello riders:
I took apart my motor to change the main bearings, when I changed the clutch shaft bearings, I had to remove the big screw with the big spring on it (look pic), I had to unscrew it and then changed the bearings, the issue is that I dont know if I screw the nut to the big spring enough. Now when I ride, it appears that the clutch pads are slippery which there are not, from time to time the motor start to jump is like I engage and disengage the clutch from time to time. The flower nut is adjusted properly. Thanks for help.
