Hi Cabinheres what it said about my dualstart dualclutch engine:
Dual GGG model; Allows pedal starting as well as rope pull engine start. Uses a friction clutch as well as a special centrifugal clutch with over running clutch lock up to pedal start; Handle Bar Clutch lever must be in the engaged position to operate in centrifugal clutch drive mode. In disengaged lever position the engine is in free wheel mode separated from drive line. Note: A standard friction clutch engine can not be converted to GGG dual mode due to different crankshaft
It also means grubby Grubee garbage.GGG means Give Gas Go.
Sounds purty cool Rohmell. Do you have any links?I bought a centrifugal clutch kit from ZoomCycles.
The clutch has a one-way sprag-type of system inside of it.
The engine can be started by pedaling and releasing the hand clutch just as before. Once started, the motor can idle at a stop without use of the hand clutch.
Here is the link from Zoom, but they never seem to have any stock anymore:Sounds purty cool Rohmell. Do you have any links?
