Now now before everyone starts mentioning that clutch let me describe the situation:
I built three new bikes (2 cruisers and a mountain bike) for some folks down here. I have a specific problem with the cruisers though. They turn on fine, idle great, run smooth, but there is a mystery noise I can't figure out.
This happens when I'm either starting from a slow speed or when I'm at speed while letting go of the throttle close to completely. It does not make noise when accelerating at moderate speeds. I understand unthrottling could explain the bogging but I get this hiccup type squeal from the engine. At first I thought they were defective motors but that would just be too big of a coincidence and they run fine all other areas.
I adjusted the clutch and still nothing.
Then I put some high performance grease on the gears and then again nothing.
I adjusted the carb to a high acceleration and following s nothing.
I'm running out of ideas and unless my recent thread
Title: Carb needle clip settings (can't post links?)
can explain this issue, I'm not too sure what else it could be other than a pooped motor/clutch.
