Bent drive shafts?
yeshua
Oregon
since I've had my Grubee GT5 I have noticed an odd sound it makes when it accelerates. And it also seems incapeable of idling even after endless effort to calibrate.
Upon opening my motor up and turning the gears I happened to notice the nut in the center of the smaller gear is off center and the teeth appear to be meshing at a slight angle. Also the threaded rod coming out from behind the clutch plate is bent quite a bit.
I've already contacted gasbikes.com to see if they will replace or fix it.
